You can delete anything in the autoexec.bat and config.sys that has an REM infront of it.
Just edit it and remove it.
From the desktop, go to Start, Run> type in:
command (ENTER)
cd.. (ENTER)
cd.. (ENTER)
edit config.sys
Anything with an REM infront of it, just delete it(if it concerns you, either way, it will have no effect).
Or got to start >run
command
cd.. (ENTER)
cd.. (ENTER)
rename autoexec.bat autoexec.bkk (ENTER)
rename config.sys config.bkk (ENTER)
then.......
del config.sys (ENTER)
del autoexec.bat (ENTER)
reboot, see what happens.
There is rarely much in either of those bootup files that matter anymore. Sometimes scanners antivirus, older soundcards etc.
In any case, since it has no effect, ignore it. REM is a remark, no effect.
If your machine is screwed after the renaming just follow the instructions in reverse.
rename autoexec.bkk autoexec.bat (ENTER)
rename config.bkk config.sys (ENTER)
anyway... doesn't sound to me like your having a problem, if it ain't broke.....
And what exactly do you mean by this:
'However, they are still there'
Where, and what exactly.
