Great peice of gear but.......
Crossever section misleading. It took 2 calls, 3 tech (inc head of dpt.), and 1 engineer callback from DBX and the final soulition is: The DriveRack your HI and LO shelves start and end points which makes you think you have to manually figure out your slope start and end points and where they crossover at whatever slope you want to use. That is not true. The graph ( as usual for any product) means nothing. It automatacally sums the crossover points. So basicly If you want your crossover between LO and MID at 100 hz, you set your HI shelf of your LO @ 100hz and your LO shelf from your MID @ 100hz at whatever db slope. Simple, but misleading. Just thought I'd let you know. Other than that what an awsome peice of gear.
