dragonworks
Banned
Alesis HD 24 24 track hard disc recorder and Tascam 24 channel console with full meter bridge, with cables.
1200. Cash or trade for guitar or amp of equal value.
TASCAM M-2600 MKII RECORDING CONSOLE
Designed for the personal and project recording studio, the TASCAM M-2600 MKII Recording Console takes the best of the original M-2600 and
packs in additional features that users asked for. Things like balanced tape ins and outs, a high-intensity meter bridge, switchable +4 and -10dB
levels and insert automation capability.
Of course, the console utilizes TASCAM's latest re-engineered, premium quality mic pre-amps, has even greater headroom as a result of a
new and improved power supply, advanced-design split EQ, and significantly improved talkback and in-place solo capabilities.
But what's really most important to the personal and project studio owner is that this unit is truly optimized for recording: It includes
dozens of application-specific features that make recording and mixing quicker and easier than ever before. Things like a true 8-bus design,
group/direct out switching on every channel (which eliminates time-consuming repatching) two independent stereo mix cues while tracking,
six independent AUX sends, six assignable stereo returns, "flip" signal assignment and much more.
Built into every M-2600 MKII is the most flexible EQ routing system available, the kind you normally find on consoles costing up
to three times as much. In simple terms, it gives you the capability of using the shelving and semi-parametric EQs anywhere you
want - either in monitor or channel paths. The dual sweepable mid band EQ on each channel lets you apply 16dB of boost or cut
at critical frequencies, along with high frequency shelving at 12kHz and low frequency at 80Hz.
Another feature TASCAM didn't compromise on when designing this new mixer is the AUX sends: You get six of them - two stereo
and four mono, all totally independent and individually assignable and all available simultaneously. They can be used for monitor or
signal and Returns are routed through any of six stereo paths which allows you to set two independent stereo cue mixes
(i.e. one for control room and one for studio). In the Control Room section there's a dedicated master level for the SOLO f
unction and an indicator light so you can quickly see if any SOLO switches are activated. The M-2600 MKII is also ready
to access a number of third party insert automation systems like Mackie Designs' Ultramix Universal Automation
As usual, space limitations prevent us from telling you more. We can tell you that list prices for the 16-channel version start
at just $3199. So we'll leave it to your Sweetwater sales engineer to fill you in on all the many other features of the unit, as well as availability and your special pricing.
HD24XR is the world's first 96kHz, 24-track hard disk recorder designed to fit into any ADAT
environment and match ADAT's legendary performance and affordability.
HD24XR is built exclusively for the purpose of recording music instead of data, resulting
in remarkable stability and performance. HD24XR enables engineers to record up to 24 tracks
of high-resolution 24-bit recording at 44.1, 48 kHz, and 12 tracks at 88.2, and 96 kHz sample
rates. HD24XR features the same A/D and D/A converters used in the acclaimed MasterLink.
Two hot-swappable media bays provide convenient access to recording drives and allow data
backup in minutes. You can edit tracks internally or easily transfer to computer via an Ethernet connection.
HD24XR features ADAT Optical and ADAT Sync, enabling it to work efficiently with existing systems.
It offers the same exceptional user-friendly interface ADAT users have come to expect.
HR24XR packs 24 channels of digital audio I/O into a single-unit recorder that easily fits into any environment.
