B
bassgirl4
So i recently got Sonar x1 Essential and was wondering if anyone knows of any free noise reduction plugins because i've got a small bit of background noise from the mic i'm using?
Thanks
Thanks
Yeah, you got a hard ratio there though. There is depth of reduction which can help mitigate that some.. 'Hold is a nice add.
The regular 'Cake 'FX dynamics does ratios all the way down into useful expansion' ranges- You might be looking at '1:1.2' or something.
Um which part what?Say what?
And this of courseA pain in the posterior I know, but you're WAY better off spending the time solving your noise problem at source. If the noise is to do with your room (fan or whatever) then positioning and a bit of acoustic treatment will help..
I'll second this. NR in Audition is amazing. I had to digitize some old recordings made on a Fostex A8LR (1/4" 8-track). Worse, still, the recordings were made in my old living room which had relatively high ambient noise. Audition was able to give me a dead flat noise floor without much, if any, effect on the recorded the sound.Not exactly free, but the NR in Adobe Audition is pretty darn good (best I know before you start spending hundreds on NR alone). Download the 28 day trial, have a play, and see what noise reduction can and can't do.
Excellent adviceWhatcha miking? Thru what else?
Standard Operating Procedure for noise (and missing signals).
Pick a box in the middle of the chain. Turn the gain up and down. Noise go with it or stay steady state?
If the noise goes up and down...
Known in some circles as the hop scotch' method.
