Jamie Jukosky
I'm looking to buy a standalone multitracker in the price range of Fostex VF16 or Yamaha AW16G. Anybody have prefer one over the other? What features do you prefer?
Jamie Jukosky said:thanks for the info. I didn't know that the fostex doesn't have the low end range.
Kramer said:The Yamaha is a little more high end piece of gear.I have the VF 16 and it's a nice machine but the low end only goes to 400Hz.
Stealth,
It's not poorly constructed either.You could drive truck over this armour covered machine.
PeteHalo said:It's not so straight forward to say which one is the better without knowing how and what you're going to use it for. Neither one of them is perfect and for different tasks one is better than the other.
As a standalone multitracker the AW16G is better but if you plan on using it togeteher with a computer DAW or record more that 8 tracks simultaneously then the Fostex is the better choice because of it's better expandability using the ADAT interface. With Fostex you can use an external AD converter or digital mixer (I use the Fostex VM88) for additional analog inputs as the 8 inputs is not that much when you have a whole band to capture live.
In a nut shell as I see it as a VF16 user provided with the usual IMHO + YMMV disclaimers. If you go for the AW you're pretty much stuck with what you get when you open the box but by going for the Fostex you have more options for expanding your system and integrating it to your other recording and editing equipment. And I'm talking about realtime integration here and not just about being able to transfer tracks as .wav files between computer and multitracker offline.
Dr. Bell said:I'm thinking about going for the VF-160, does this low end limit hold true for it as well?
