sjfoote said:Any soundcard (or onboard chip for that matter) that has a MIC input, whether 1/8" mini plug, or 1/4" plug, has some type of preamp. Even cards like SoundBlaster that have one shared input (MIC/LINE) have a preamp in the circuit if you select the MIC option....
bennychico11 said:this is incorrect.
several PCI based sound cards contain mic preamps. For example the M-Audio Delta 1010LT has two:
http://www.m-audio.com/products/en_us/Delta1010LT-main.html
the actual physical connection to the computer doesn't denote whether or not it is manufactured with preamps.
TravisinFlorida said:The pre's on the 1010lt don't count. They're junk.
bennychico11 said:that may be....but they're still pres
I'd personally prefer to keep the soundcard and preamps separate. Like I said, now I use a firewire interface and I would not like to be relying on the pres in that (Tascam FW1082).Reilley said:I'm undecided whether to get a USB/Firewire interface with preamps, or a PCI card and then a separate preamp. From what I've read, I'd be able to get somewhat better sound from a good PCI card - say, an M Audiophile 192 oe Emu 1212M - and a DMP-3 preamp, than I would from an entry-level USB/Firewire with preamps, and for only a few bucks more. Whether that "better sound" would be audible in a CD, I don't know. One wants to get the best sound one can, within reason. [I don't need mobility.]
Kevin DeSchwazi said:You think it'll be a pain ferreting around at the back of the comp but once you're set up your preamp is your front end which can be always hooked up to the comp and you just have to plug/unplug mics at the preamp.
My point exactly.TravisinFlorida said:Yep, same as any other interface in that respect.
TravisinFlorida said:That's almost debatable.
Reilley said:Well there you go. Thanks for the replies. It looks like the DMP-3, plus either the
M Audiophile 192 or Emu 1212M.
'It's beginning to look a lot like Christmas.........'
