I am reposting this in a new thread as was suggested.
I am trying to install the driver for an M-Audio 410 Firewire that I am first getting to after 4 or 5 years. . I also have a midiman uno connection with a USB to computer and two midi (in and out) I downloaded the driver to my laptop (Windows vista 64 Bit). Everytime I plug it in it starts searching for the driver and then says can't locate it. I already downloaded it and even did an uninstall and reinstall a couple of times. M. Audio control panel is located in the lower right hand corner and all the files are there.
I then tried it on my computer with Windows XP 32 bit. Samething. Then realized that the cable might have it's own driver and it did. So I downloaded it that. Similar problem, everytime I connect it to the computer, it says searching for the midiman uno driver but I'm 99% sure it's installed. It even recognizes it as a midiman uno whereas when I connect to my vista computer it says it is not recognized.
Went back to vista to download the uno driver and it says that it doesn't need a driver in Vista.
Neither one is working. I never used the firewire or the cable but they are about 3 or 4 years old.
It seems it should be a 1,2,3 download but either i'm doing something wrong, the old midiman uno is not useful or some other minor thing I'm overlooking. I've not got the firewire to light up when I connect it. I assume you do not need the adapter with this cable.
What can i do to get fix this?
Thanks
David
Thanks
David
