H
		hairylarry
Hi,
I use a Zoom H4 for field recording and I have a problem. Maybe someone here has had to deal with this situation and can help me out.
I was recording the Hoggard Brothers at a KASU Blue Monday show. I recorded the first set fine. Then after the second set was done but before I stopped the recording there was and accident and the power went off on my recorder. The file for set two is there all right but it shows as zero bytes.
If I look in a hex editor I can find the file header and look at the wav file data. I just can't listen to it or copy it to another drive.
I just did post on the first set and it sounds fantastic. So this makes me want to recover the second set even more.
Does anyone know how to recover wav data like this. It's on the flash card ok. It's just not part of the FAT file system because of the inadvertant power off before the file was closed.
Thanks,
Hairy Larry
Thanks,
Hairy Larry
