			MONTE
I have been trying to figure out why I can't get my overall CD volume up to current "standards", and I have discovered that many of my tracks (mixing with a daw) have higher peaks in one direction than the other (especially drums). I scanned the files for DC offset, and the program says there is none. The wave form is centered, but the initial attack of the sound goes (for instance) up to 0db in the positive direction, but maybe only -3db to -6db in the negative direction. Obviously this is going to limit the overall volume before clip. My question is, "What should I do about this?" . If I add a DC offset to the wave to better center it, will this create adverse effects to the sound? Should I just limit the sound some more to "chop off" the peaks in one direction? There must be a "best" way to correct this problem. The sounds have already been compressed and limited quite a bit, but maybe more won't hurt? If anyone can help I'd appreciate it. At least I know finally why I can achieve a good sounding mix, but can't get volume before clip! Thanx in advance to all who reply!
