shadow5606
Hey there folks, wondered if any of you are using any particular plugins that you really like and would reccomend?
I'm running Cakewalk Sonar 2.0 and have just been using what it has for the most part.
My most used plugins are EQ & Compression. I'm using the the Timeworks / Sonar XL version of both EQ & Compression. (i.e. Process > Audio Effects > Timeworks > CompressorX (Sonar XL)) and (Process > Audio Effects > Timeworks > Equalizer (Sonar XL))
For Reverb I've been using the Cakewalk FXReverb (i.e. Process > Audio Effects > Cakewalk > FXReverb)
I'm open to any FX you like an think may be better than what I'm using. I'm also open to different FX than I'm using now. Most of the time I'm recording my Taylor acoustic guitar, my voice which is a little low and a little rough. (in a Steve Earle sort or rough way) When I record Bass Guitar I typically run it straight through my board into Sonar.
I'm using Sonar of course and my main mic is a Rode NT1A. I also have Steinberg WaveLab 4.0 which I will sometimes use once I've mixed everything down to a wave file.
Any advice would be great!
