what exactly is the master fader? is this the same as the master volume?can't you put a volume envelope on the master fader?
Yep.v6v6v6 said:what exactly is the master fader? is this the same as the master volume?
andvolume envelope on the master fader
how does one put a volume envelope on the fader (volume)?use a volume envelope on the channel fader to do the fade
Actually you put the volume envelope on the Track or the Master Bus. The envelope will then control the fader.v6v6v6 said:ok, i'm not sure i understand how this would work. and how does one put a volume envelope on the fader (volume)?
does this mean i can put a volume envelope on the track's volume slider? or maybe you put one on an entire track (as opposed to a sound clip)?volume envelope on the channel fader
I am not familiar with GT2, but most Cakewalk programs allow you to create clip volume envelopes and/or Track volume envelopes. A track volume envelope runs the entire length of the track (usually beginning of the song to the end) and it will allow for automation of the volume of that track. (When someone refers to fader they are talking about the slider that controls the volume. "Pull down the track fader," would mean to decrease the volume of the track.)v6v6v6 said:perhaps i'm not understanding the terminology... i'm still new to all this.
fader = volume slider that you pull up/down
bus = ??
channel = track (of which any number of sound clips may be contained)
i know how to put a volume envelope on a sound clip, but when strryder says does this mean i can put a volume envelope on the track's volume slider? or maybe you put one on an entire track (as opposed to a sound clip)?
thanks.
Oops. The things we take for granted..v6v6v6 said:...as far as i can tell, GT2 doesn't have the ability to place a volume envelope on a track or master fader.
Don't know GT, but Cakewalk's site says one of the key features (of the latest version though - but wouldn't think this would be newly-added) is "Accurate envelope automation of mix parameters and effects". If they don't consider Volume a mix parameter, I don't know what they think that means. Anyway, you say putting the envelope on a "fader", so I just want to double check that you're trying to add the envelope the right way. Did you check the help on it? In SONAR, (and from the screen shots of GT on Cakewalk's site, they look similar) you create a volume envelope by right-clicking in the track where you see the waveform and selecting Envelopes->Create Track Envelope. Then, Volume is one of the choices of Envelopes to create. Do you not have this option when right-clicking? Another way of doing it is to right-click on the volume fader itself and select Arm for Automation. Then, instead of drawing an envelope graphically yourself, you just ride the fader and your movements get recorded and you can then choose to represent the recorded movements as an envelope. Anyway, too bad if GT doesn't have this, but just figured it might be work another quick look.v6v6v6 said:dachay2tnr, thanks for the explanation. as far as i can tell, GT2 doesn't have the ability to place a volume envelope on a track or master fader. i guess it's a minor inconvenience that i can live with for now.
1) i'll probably just keep doing what i do now--combine sound clips, adjust the sound clip's volume envelope so they fade accordingly, etc. or 2) i've thought about upgrading to GT3 since it's $99 for the upgrade...mixsit said:How about a plan B? If the facilities are there to play and output the mix while recording a loop of the signal back in to a new stereo track, could you do the fade manually?
right-clicking on a sound clip in GT2 brings up Envelope > Create Volume, but i can't a way to get it on the whole track.guttadaj said:In SONAR, (and from the screen shots of GT on Cakewalk's site, they look similar) you create a volume envelope by right-clicking in the track where you see the waveform and selecting Envelopes->Create Track Envelope. Then, Volume is one of the choices of Envelopes to create. Do you not have this option when right-clicking?
the only option when i righ-click on a fader in GT2 is Ungroup All and the only mention of Arm is to arm a track for recording.guttadaj said:Another way of doing it is to right-click on the volume fader itself and select Arm for Automation. Then, instead of drawing an envelope graphically yourself, you just ride the fader and your movements get recorded and you can then choose to represent the recorded movements as an envelope.
will do, and also will ask in the cakewalk forums.dachay2tnr said:Double check your manual or online help files.
v6v6v6 said:as far as i can tell, GT2 doesn't have the ability to place a volume envelope on a track or master fader. i guess it's a minor inconvenience that i can live with for now.
