BroKen_H
Re-member
Sometimes it helps to "duck" the signals. If you side chain compress the bass guitar from the kick signal, (1ms attack ~250 release 3-4:1 ratio set threshold to taste) the bass still sounds natural and the kick shines through better. Ducking the guitars from the vocal signal will do the same, but you'll want a slower attack and quicker drop off (3-10 or maybe more ms attack, 100-200, or even less release). These are settings I use WHERE NECESSARY. Nothing is guideline or set in stone...
There are leveling compressors, which bring the quiet notes up while leaving the hot hits alone. You need to use a regular compressor afterward (or before), because it basically just lets loud through and doesn't care about clipping or whatever. The one I use is called Sellig Leveler, but of course it's an RE, and I don't know if it's available in AAX or whatever.
One of the hardest lessens I've learned is to not over do things. It's fine to run a glue compressor at 1.1:1 into a leveler to bring up the bottoms, and then into a C1-L1 to pull the top down and still have a final compressor and limiter on the main bus, but getting them all to play "nice" takes a lot of patience and (at least for me) a bit of finesse. The first comment I used to get on ALL my mixes was "overcompressed". But yeah, I've learned to use volume instead of compressor and just put a glue compressor on the vocal bus or the drum bus or whatever just to keep the clipping out.
