Exporting audio files from Cubase to an external drive.
drumminman
Hi all, a newbie to this forum. I am trying to clear my hard drive and want to export several Cubase 4LE projects to an external drive. I don't want to send the mixed stereo file, I want to send the whole project (14 tracks). What would the procedure be?
Thanks in advance,
Ed
I don't have LE4 anymore, but in LE5 on through 6, there is an option under File>Backup Project where you select a new project folder on any drive. If I remember correctly, this wasn't as easy on LE4. Look under Save As and see if there is some option for saving whole project folder. Otherwise, if you kept your projects well organized, you can just copy the project folders from your hard drive directly to the external. Just make sure you have the Audio and Images files together along with the cpr files in the SAME folder. Otherwise Cubase will be lost as to where the audio files and waveforms are.
