Just purchased the Radio Shack digital sound level meter for $50. Best purchase I have made to follow-up my recent nearfiled monitor purchase two weeks ago.
I used it to fine tune my monitor gain levels, so each side was equal in volume. Then I looked behind and the gain level knobs were about two ticks apart. So, visually using them is not accurate. Using my ears, was not as accurate either.
After tweaking my monitors with the SPL meter, all of the sudden they opened up and the stereo imaging was much much improved. I actually could monitor at lower levels with better clarity as well.
I used combinations of pure sine wave generation, white noise and pink noise. Very close to the speaker components, an inch to two inches away. If an inch away from the woofer read a consistent 88db max, then two inches away read 86db, then three inches away read 82db; I tried to duplicate that "db fall off" with the other monitor.
I also have used it to find out what listening level I am at. I like 75-80db or so from my listening position. Now I can know exactly, what levels I am monitoring at. Putting the DB meter at my left ear pointing to the left monitor and reading 78db, then getting exactly the same result on the right side. Yes !
Also, running low frequency sine wave tones, I could find all the bass frequency build up areas in my room and what frequencies they are at. So I know where the best spots are to treat.
GO GET ONE NOW !!!
GO GET ONE NOW !!!
