EqualizerPRO Settings Help
  • Thread starter Thread starter Jamesaston
J
Jamesaston
I have installed free version of EqualizerPRO. It has 7 days free trial version. After installing it my PC goes mute. No sound was coming out. Then I uninstall and re-install it. Now it is working. As it has more than 20 settings but I am not sure it is working properly or not. Anyone using EqualizerPRO?
Hi James,
Welcome to the forum!
It should be fairly obvious if it's working or not. Presets with consumer eqs are usually pretty extreme.
If you drag any of the sliders to +12 or whatever the max is, you should know straight away if it's doing something or not.
I don't know that specific app but, if you're confident it's not doing anything, look for settings in it to let you tell it which device/stream/output to eq.
Assuming it's meant to be a global system EQ, you'd choose whatever your output hardware is.
Thanks for your replay. I contacted with their support and it is working perfectly.
