R
RAMI
Guest
Thanks for that. So, according to that I should insert an EQ Plugin, cut all the frequencies that I need to, then insert compression, do all my compression, then insert another EQ Plugin and sort out anything that I want boosted?
This stop the compression affecting boosted frequencies in a negative way.
So will this just make it easier to control the compression basically? And is it really recommended or is it something that you would do if you were having issues with EQ and compression?
