<Hmm, being a JFET it should see a diode between gate and either source or drain regardless of how asymmetric they are. I can't explain why it wouldn't see one from gate to drain. Puzzling.>
Yeah, but hey Bob, who knows, probably there is a diode there
You know, you gave me idea to try to reverse drain and source in my, 3-wire arrangement and see what happens.
<They both sound very similar - and very good - must be your pre. The one labeled "left" seems to be more defined - noticeable to me particularly in the strum of the Em chord mid-sample. But my recording and monitoring equipment are primitive, and my ears' frequency response is far from the norm.>
Yeah Crazydoc,
As I and Nat have mentioned above the difference after converting to MP3 is much less obvious then in my 24/94 setup.
Actually, I think that another reason is that Nat played very quietly, where the head preamps work with very little signals and from the very beginning it reduced the difference, I am used to. With wide spectrum signals and higher levels the difference is much more noticable. Next week we will try to record guitar again with higher volumes, and also make some drum OH tracks.
I have some more ideas about the capsule shape and size, so please reply in the 'Earthworks mic' thread if somebody has that information.
