I'm trying to correct the frequency response of my monitors/amp/control room. The method that I'm using is to play back white noise (stereo, uncorrelated, to avoid phase/comb filter problems), recording it through an ECM8000, and then doing spectral analysis in SoundForge. I'm applying the correction by strapping a parametric EQ on the master outputs of Cubase during mixing, then removing it when rendering a final mix.
Two questions:
1. Is the ECM8000 accurate enough to be used this way? I know it's what it was designed for, so I sure hope so.
2. Does the rest of this procedure sound like a smart thing to do? I've been able to flatten out my NS10M Studios to +/- 2dB from 65 Hz - 20 kHz.
On a related note, but a bit OT for the microphone forum: the response curve for the NS10M Studios in my control room had a *huge* peak (+11 dB) around 200 Hz. Does that sound right?
Two questions:
