F
FourEyesRock
I have an echo layla 24/96 and im using cubase. Whenever i try to record and playback i can only record in 16 bit (analog) and playback in 48 khz. Arent i supposed to be able to record in 24 bit and playback in 96 khz? I changed the settings and everything but it just says song set does not match something rate...what the hell? And when i mix down to .mp3 (mpeg layler 3) it only goes to 16 bit 48 khz....but in that it mixs down to nothing and when i play it its just quiet and blank and nothing is there. SO when i mix down to 16 bit 44.1 khz then it works fine...i dont get it...why cant i use the full potential of this system?
