Ease of bending depends more on your bridge than the frets.The straightness of the bridge conflicts with the curvature of the neck,so you get a scraping as you bend.Adjust the bridge saddles to follow the curvature of the neck exactly.Also,putting (via trussrod adjustment) a slight upbow in the neck (called "relief") helps to eliminate the buzz when bending strings across the neck.
