H
Harvey Gerst
DonF has it 100% correct. A pressure mic is like a barometer that operates in the audio range. It responds to pressure changes in the room.
krs said:Is it possible to have a hypercardioid pattern without the rear lobe?
Conversely, having less pressure than velocity tilts the balance toward the bi-directional pattern. This more directional pattern is usually called a hypercardioid (Figure 3E). It is more sharply focused forward. Because it is less pressure than velocity, however, there is no longer perfect cancellation at the rear. The hyper-cardioid develops a small rear lobe of sensitivity that is the residual rear lobe of the bidirectional component.
krs said:Is this difference in pressure/velocity acheived by different voltages across the diaphragms? Or? I feel like I don't understand something very basic about how one creates a diaphragm to be one way or the other.
Sorry to be nosy![]()
easychair said:Harvey, I hope you don't mind me jumping in, I've followed your contributions for years.
krs,
Maybe a little info on what sound is will help. Sound waves aren't really waves. They are areas of more and less pressure. When you see a sine wave picture of a sound wave, it is just a numerical/graphical representation of higher and lower air pressure passing a point (like a microphone) These areas of high and low pressure move from a source (like your mouth) through the surrounding air. So sound is said to have both pressure and velocity. How many times per second the pressure goes up, down, and returns to the zero point is the frequency (one full sine wave, in all those fancy pictures). How high and low the pressure goes is the SPL, sound pressure level, what we usually call loudness or volume.
The difference between pressure mics and velocity mics is in the capsule design, not the diaphragm itself. A mic capsule is the diaphragm, and an airspace behind it.
A pressure mic is like a filled baloon, literally. It is a sealed airspace, with a flexible boundary (the diaphragm). Behind the diaphragm, the capsule is sealed, no air gets in or out.
Put the baloon in a room. Hook a tube to an air pump and feed it into the room. If you pump air into the room, the baloon shrinks. If you suck air out, the baloon expands. It reacts to the pressure changes. When you speak, you change the pressure in the room just like the air pump. The pressure mic reacts the same way as the baloon.
A key thing is that the direction of the source of pressure change doesn't matter. Your air hose could be in the ceiling, floor, or wall. The baloon will react the same. In the same way, it doesn't matter where the sound comes from when using a pressure mic. The pressure mic reacts to the overall pressure changes in the room.
A velocity mic is an open airspace. There are holes in the capsule. It's like a tom-tom with no bottom head. So if you just pump air into the room, the diaphragm won't move, because the pressure on both sides of the diaphragm stays the same. A velocity capsule and diaphragm react like a piece of paper in front of your face. When you speak at it, you create sound waves, areas of high and low pressure with a velocity (they move, in other words). Hold the paper flat side towards your mouth, and it flutters back and forth. The higher and lower pressure on the front of the paper (relative to the ambient room air pressure on the back of the paper) as the sound waves hit the paper cause the paper to flutter back and forth. Hold the paper edge-on, and when you speak the paper does not move. There is equal pressure on both sides of the paper at once at all times as the sound waves hit it.
Pressure mics are omnis, directional mics are velocity designs.
Both types of mics rely on pressure in the end, but velocity mics absolutely depend on fairly rapid pressure changes from the right direction to be effective. If there is time for the pressure to equalize on both sides of a velocity mic diaphragm, it will not react. This is the basis behind various directional patterns. Sound waves coming towards the back of a cardioid mic, for example, are delayed so they reach the diaphragm at the same time as they hit the front, so the pressure is balanced, and you get no sound. The holes in a cardioid capsule aren't just holes, they are special, designed to delay sound waves just the right amount so sound from the back of the mic hits the back of the diaphragm at the same time it hits the front.
The terms velocity and pressure are a bit arbitrary, but they work.
Thought experiment:
Say you could make a sound wave stand still. That is, you could move a mic along the wave, instead of moving the sound wave past the mic. With a pressure mic, you could move it as slow as you wanted and get accurate results, even stop in the wave, as it reacts to absolute pressure, due to it's sealed capsule.
A velocity mic needs to keep moving. It's open capsule will allow the pressure to equalize on both sides of the diaphragm if it stops or moves too slow.
Theoretically, a pressure mic could measure any frequency, no matter how low. A velocity mic will be limited in low-frequency response by nature, once the frequency gets low enough, as the pressure changes happen too slowly.
krs said:That's starting to get complicated![]()
So Marik what you're describing is in fact a different design of mic with 2 diaphragms, which is not a true omni rather a 'simulated' velocity omni, right?
I tried.You must spread some Reputation around before giving it to Marik again.
