ducking vs unmasking
paresh
Member
Does anyone ever use both together for a vocal track to come through over instruments & pads? Is ducking on a vocal track more for spoken audio? Any thoughts are appreciated.
No idea what unmasking even is?
Ducking is simply automated fader controls - turning a bed or backing down when the mic is active - and most folk automate that nowadays for more accurate control - or at least I know I do. Ducking in the old radio sense is a bit crude for recording. You rarely want the level adjustments to be that course.
Maybe unmasking is only generic to Izotope - it is recognizing frequencies that maybe interferring with each other and filtering out those frequencies on one of the tracks or busses so the other is more clear (as opposed to lowering the volume level).
I hadn't heard of the term unmasking either but, from your description, it sounds like automatic eq.
Most people mixing a project are going to do that by ear, notching down certain frequencies or areas in, say, guitars or piano, to allow a lead instrument or vocal to be heard more clearly.
There's generally three tools you can use to move things out of each other's way.
Eq, panning, and distance (ambience/reverb).
For ducking I don't know how common it is to use it on vocals in music but certainly for dialog it's used a lot.
Any time you hear the music track disappear, on a radio show or podcast, right as the host speaks, that's ducking.
It's also very commonly used in electronic and beat driven music to completely clear the way for the kick.
It's often used to the extreme in that case - You could call it pumping.
I don't see why you couldn't use ducking on vocals in a mix but as with every 'fix'
it might be worth asking if there's a fix that can be employed earlier in the process.
If you're finding some instrument is drowning out your vocal maybe something could be changed in the recording process to eliminate that problem?
Great answer, thanks. The Izotope unmask is some kind of dynamic EQ.
Dynamic EQ is correct. There are lots of plugins that do this these days… Basically, it like a signal analyzer and multiband compressor sidechained to an EQ. It applies an inverse EQ curve after analysing the sidechain signal to duck conflicting frequencies.
