C
cerulean
At my church, we have decided to get everything through our sound system. As a result, we need to mic the drums.
I have the following questions:
Drum Shield -- 4' tall panels vs 5' tall panels? Whats the difference? I'd assume taller is better? How about thickness? Is 1/4" adaquate?
Acoustic Foam -- I was thinking foam on the lower portion of the shield (ie lower 2') to absorb the kick & toms as well as some foam on the wall behind the drummer.
Mic Setup -- 4 mics total (2xoverheads, 1xkick, 1xsnare) -- is this good? Too much? too little?
overheads considered: MXL603's .. given that the setup is for a monosound system, is it necessary to have two mics or will one be enough? What other options should we consider?
Snare -- SM57 -- seems standard & durable .. anything else to check out?
Kick -- Beta 52 or AKG D112 seem to be fairly common suggestions --- any other thoughts (or perhaps recommendations for one or the other)
Unfortunately we will have to submix the drums to one channel .. so I was thinking running the mics through a Behringer UB1202.
So what do you all think? Anything I should be aware of that I have not mentioned? Thanks for any advise you can provide
Oh FYI -- the budget is around $1100 or so for everything (shield, foam, mics, mixer, etc..)
