shockingcandy
Leads for all occasions
Not sure if this is the right place to ask this question but...
I am trying to improve the headphone monitoring at the studio I have just become the engineer at.
Basically, the wall box in the live room has 8 jacks wired in parallel (each in series with a 100ohm resistor presumably to prevent damage in the event of a short circuit). The headphones we have are mainly the 400ohm DT100s. Previously, these were being driven from a single output of a headphone amp. Predictably things were pretty "quiet" so I have rigged up a Sony Hi-Fi amp we had lying around instead.
Now, the speaker outputs feed the wallbox and the amp gets it's signal straight from the console monitor outs. This works for a minute or so then the amp trips out only to return 10 or 20 seconds later and the cycle is repeated.
Anyone know what the cause might be?
