DP-24 problems / issues
  • Thread starter Thread starter cwhowell2
C
cwhowell2
I noticed one issue that does not seem to be fixed in the latest update. When hitting the Phantom button a second time to turn the 48v off before unplugging, the Phantom light goes off but power is NOT removed. The mic still works indicating power is still on. - Bill
Bill,
If you let the mic stay hooked up for a while after turning off the Phantom power does it still work? Just wondering if your mic doesn't present much of a load and it takes a bit of time for the Phantom power to fully discharge.
Yep - That's the issue. I plugged the mic in and tested to confirm it was dead. (making sure it was a powered mic). Then turned the phantom power on. Mic came alive. Then I turned the phantom off and continued to test. The mic worked for another 15 - 20 seconds before going dead. Lesson = "be patient". Thanks for the advice. - Bill
