I have always played around with different ways of setting up. There are many schools of thought on this. I've seen arguments that say that you put time affecting effects (like delay) on your chain last, others that say they should go first. I think it's dependant on what sound you are trying to accomplish. But then again, I am for minimal effects: distortion, reverb, sometimes chorus, or simple delay. I don't like to wash my sound in effects unless it adds to the sound.StupidKid said:Just curious as to what is the preferred way to run effects. like is it supposed to go, compressor -> eq ->reverb orrr... just curious as to what works the best
Massive Master said:For instance - EQ and compression - *Corrective* EQ (rumble removal, tubbiness, sibilance, plosives, etc.) should be removed before compression.QUOTE]
thanks alot for the info, so would this help with getting rid of some spikes when im mixing my drums, because i sometimes get spikes when i do a rimshot on the snare even after compression
