mshilarious
Banned
"Trolls"? Or people with legitimate opinions and arguments?
VP
You've had plenty of opinions and arguments, but precious little experimentation and evidence.
VP
What is lacking? Can you identify it via measurement?
Are you sure it isn't filtered out by the output electronics on the tape deck? It obviously doesn't make it too far down the chain from the tape deck...Oh, the 150kz bias signal? Well it certainly ain't from A/D D/A conversion!
You dont hear it because you dont have "Bat Ears". It is there.
VP
If soul can be generated by electronics, why are musicians necessary? Can acoustic music have soul?
Followup question: when Dennis Wilson sang "You got so much soul you blow my mind", did he mean that the object of his affection had many reel to reel tape recorders?
Well, I am sure it gets attenuated being such a high frequency, and I assume that was the intention in its development. I could record silence then look at an output waveform on my O-scope and see what is there.
VP
The analog tape recording process actually samples at two rates: twice the bias frequency (as every half cycle drops to the level where the signal is retained near the trailing edge of the record gap) and at the random rate of the asparity noise. Asparity noise is produced by the statistical distribution of oxide particles in the record head gap vs time. This noise is different from the simple fixed thermal noise of an amplifier, which stays at one level, regardless of the level of the signal. If you put a tone through a tape recorder and watch the output on a spectrum analyzer, you will see that as the signal level is raised the noise rises up around it in a mountain, with peaks at the odd harmonics. The truth of the matter is that tape recording is shaped noise. It is a non-linear transfer process that produces noise-like sidebands for every frequency in a complex signal. This is a major componant of the tape sound.
Another distinctly aspect of tape is the approach to saturation. The tape headroom sound and the mechanism that produces it are very different from the way an amplifier overloads. As level is increased, the tape, again by a noise-like process of statistical distribution, gradually runs out of magnetic domains that can hold each higher energy level. Also, at high flux levels the present signal is self-erasing the just previous one. These effects together produce a gentle “S” shaped onset of distortion, the famous tape compression.
There are also time delay dispersion effects in the magnetic recording process that do some rather odd things to the time relation between low and high frequencies. As an experiment, fly an impulsive signal, like a kick drum with a good sharp high frequency edge, a strong deep bass thud and a clean, well defined start time, from your Pro-Tools (or whatever) editor into an analog tape recorder. Now fly the reproduced tape signal back into Pro-Tools and try to line it up with the original. Something funny happens; when the two high frequency energy peaks line up there is energy appearing well before the main spike in the tape processed signal.
Maybe, but tons of tape has been lost to negligence or practical considerations. A lot was simply thrown away. Other tape was recorded over, sometimes another session, sometimes other tracks on the same session.
Most people are going to be too lazy for proper backup procedures, tape or digital, that's the reality. Where is your tape stored? Your house? Is it protected from fire? Do you have backup storage offsite in a fireproof location?
It is so cheap to make multiple copies and offsite copies of digital music that is facilitates the process *if* the engineer isn't completely lazy.
One can also release music to the public via any number of sites which means that many more copies will likely be created and stored in various locations.
Maybe he should speak for himself.
VP
I think Beck might have been saying this, but this isn't a debate about the merits of analog vs digital but a debate about what more accurately represents the test equipment. And digital SHOULD win because the test equipment is the exact same thing that the digital format is. Everything should match up inside the box! Test equipment is not your ears, but digital wins!
