My recently purchased DMP3 has an issue that I thought I'd bring here for discussion before I start the hassle of returning it for service.
If both channels are providing phantom power, there is a distinct 60 Hz hum (along with pronounced 120 Hz and 240 Hz harmonics).
Here are the list of situations where it doesn't happen:
* No mics plugged in, phantom on.
* One condenser plugged in, phantom on.
* Two cables plugged in, one connected to a condenser, one unconnected.
* Any number of dynamic mics, phantom on or off.
* Any time the phantom is off, regardless of what is plugged in.
Here is the list of situations where it does happen:
* Two condensers plugged in, phantom on.
I use high-quality cables (various brands, including Monster and Mogami), so the cables are not an issue.
With the High/Low switch set to low, and the channel gains at about 90%, the hum is about -36 dBFS, according to Wavelab. That's, umm , unacceptable. Because I really want to use this for stereo pairs (drum overheads, acoustic guitars, etc.) this is obviously a big problem for me.
I'm wondering if this may be caused by a substandard power supply (wallwart). Can any of you smart folks tell me if drawing more from a PS than it wants to give might cause AC hum in the audio circuits?
IOW, should I try a higher-rated PS before going through the return/repair process?
Alternatively, can anyone suggest an inexpensive, clean, two-channel phantom supply I could just stick between the DMP3 and the mics?
