Yep, if your monitors aren't too heavy PVC stands are easy to make and can be customized to any size you need. Another trick to use with them is to fill them with sand before glueing them together, this eliminates any resonance the hollow tubes might have. And glue carpet strips on the tops and bottoms to eliminate viberations.
