Marik
Pro Microphone Design
DIY capsule. Q for Bob, Harvey or anybody who cares
I had an idea of push-pull capsule for a loooong time--since I was into building electrostatic speakers and repairing Quad57 and Martin Logans. Today I made a search on RAP and stumbled into this thread:
http://groups.google.com/groups?threadm=8clajc$fsv$1@fcnews.fc.hp.com&rnum=1
Some common sense tells me that the first reply was from Arcanemethods. Bob is that right?
So here some questions. First, I have always been wondering why mic diaphragm should be metallized? Once again, from my electrostatic speakers experience, graphite can be rubbed into diaphragm to make it conductive. Its high resistance will be only of benefit for the mic. The only potential problem I could see is a humidity, but high Ohm resistors would take care of this problem.
A few times I posted about it on TT, but nobody picked the idea.
The biggest problem with this design, as I see it, is a tuning resonance of the diaphragm. In this configuration (like in ribbons), because of the forces on diaphragm, the whole system should be mass controlled, so it should be tuned at the low frequency of the band. In the electrostaic field the diaphragm can become unstable; or without having enough tension-stiffness, with 35 micron or so spacers, start bottoming backplates. Increasing width of the spacers will take care of this, but will reduce sensitivity, which can be taken care of by increasing polarizing voltage.
Another solution would be tuning the diaphragm to the mid band, making it resistance controlled, and then EQ it.
Gentlemen, what do you think? Any fresh ideas?
I am tempted to try it... then add an omni capsule and get a nice
variable pattern.
variable pattern.
