C
		CMEZ
I'm at a bit of a loss...
Okay. I'm borrowing a Shure KSM 44 for some demo sessions; the console is an Allen & Heath System 8, analog 1/2" 8 track. All the instrument tracking is done and sounding great.
So, tonight I plug in the 44, and start rolling some 'keeper' vocals. Without padding anything, the big voiced female singer is distorting something. So I try to pad at the board; doesn't sound good. So I pad the mic. Sounds...small, and her voice is anything but. I move her back, and it gets thin. I put an RNC on her, supernice mode; I try compressing moderately to compensate for the dramatic volume difference, doesn't work-she's still distorting on the loud sections if the quiet sections are at usable gain. I try setting the RNC basically as a limiter 20:1 or whatever the max is, at +5-ish threshold. Sounds like ass.
I'm of the opinion that this mic just does not like this singer AT ALL; but I can't help feeling that I should've been able to get a USABLE sound here. It IS a quality mic; and the rest of the tracking has gone remarkably well. Professional engineers have had mixed results with her in the past; the best sound she's gotten was with a Lawson '47, which is considerably out of our price range.
So I'm going to try an SM7 and hope that solves the problem; and it might; but can you think of any possible solutions that I didn't try that might've worked? This singer is like a young Aretha Franklin type; similar range and power. I've been holding off on buying a mic until I find one that works well for her since we work together so closely (2 bands).
I should add that on quieter sections, the '44 sounded quite good, EQ flat, no 'ess' problems, no plosives, didn't even need a pop filter. I suppose I could've had her sing the quieter sections and then overdub the louder sections at different settings, but there has to be a simpler way...and one that would be less obvious; I'd still have to either pad or move her way back off the mic, which would be an audible difference in the track.
Thoughts?
Chris
Thoughts?
Chris
