Mike Freze
I understand that my interface (TASCAM US-122L) has a sound card built into it, AD/CD converter. pre-amps for each input, input level controls, all that. It is a 2.0 version (lowest of latencies, fastest speed).
So if one has an interface like this (even though it's only two line-level inputs, two mic inputs, and a midi input/output), why would you ever need a direct box or a pre-amp for instruments or vocals?
Are the sound cards built into the interface much superior than the computer sound card one used to use by connecting directly to it?
Also, since everyone needs an audio/midi interface to get signals into your computer to record, what's the point of an external hardware mixer?? A computer sofware program has a mixer as well. Outside of the fact that you can connect hardware effects pedals/devices with an external mixer (or maybe have more input channels from real instruments), I don't undertand....IF you used an external mixer (I have one) or a Studio-In-A-Box (I have a Fostex 16 tracker), again, what's the point? Mine has a hard drive to store songs, some effects included, digital readings for EQ, panning setups, a CD drive and burner built right in, and so on.
If you use a Studio-In-A-Box like I have, does that still have to be connected to your interface box anyway to get the recording into your computer? Or can you by-pass your interface (like my TASCAM) and connect your hardware mixer DIRECT to your computer? If not, then it sounds like one more step in getting your songs on your Studio-In-A-Box into your software program on your computer. If the interface is still needed, why bother with a hardware mixer?? Migfht as well just go direct to your interface from your instruments (amped/miked) or vocals.
Mike Freze
Mike Freze
