I looked around alot for one of these too. I ended up with a Friend-Chip DMX 12/12. Works great and handles 24 bit. Heres the specs.. Good Luck. Oh, and stay away from the Midiman or M-Audio digipatch. No software control or 24 bit. Theres no much out there ... trust me.
Friend-Chip - DMX 12/12 Digital Patchbay
12x12 (stereo pairs) Matrix Patch Bay/Distribution for Stereo SPDIF and 8-channel ADAT signals. Includes MAC and PC control software.
· 12 x 12 crosspoint matrix
· signal distribution
· 6 coaxial in, 6 coaxial out
· 6 optical in, 6 optical out
· optical <> coaxial conversion
· 6 x ADAT routing
· software controlled
· 50 memory locations for presets
The DMX 12 offers a 12 x 12 crosspoint switch matrix and signal distribution. Any sources can be distributed to several outputs, but one output can only be fed from one source.
Optical SP-DIF sources can be routed to coaxial SP-DIF destinations and vice versa. All optical receivers and transmitters can also handle the optical ADAT signal. ADAT format can be switched and distributed for other ADAT receivers, but not be converted to SP-DIF format.
The DMX 12 can be programed from the front pannel or be remotely controlled from PC or MAC software with MIDI sysex or MIDI program change commands.
· MATRIX: 12 x 12 crosspoint matrix
· COAXIAL: 6 x SP-DIF 0.5V +/- 20%
· OPTICAL: 6 x TOSLINK for SP-DIF or ADAT "lightpipe"
· RATES: up to 24 bit, 96 kHz
· PRESETS: 50 memory locations
· REMOTE: MIDI program changes
· MIDI: sysex. remote software
Regards,
Mountaineer
