"Western Digital" My Book – Home 3.5” 750GB USB2.0 / eSATA 3Gbps / Firewire400 (Black)
Are you running out of hard drive capacity? Do you need to archive some important digital documents, photos, or music? This elegant external hard drive, reminiscent of a book, is the perfect solution. It takes no more space than a paperback book. Collect two or more and they nest neatly together like volumes on a shelf. Gain instant storage. Small, simple, elegant, and very easy to use. Just plug it in, and you've got plenty of room to back up and save your valuable data, music, photos and movies.
Manufacture Link:
http://www.wdc.com/en/products/products.asp?driveid=356
Specifications:
Features:
Flexible triple interface - eSATA 3 Gb/s, USB 2.0, FireWire 400 (A high-performance interface that's perfect for Macintosh® computers)
Capacity gauge - See at a glance how much space is available on your drive (Works with the USB and FireWire connection only)
Smart and energy efficient - Turns itself on and off with your computer and Safe Shutdown™ prevents the drive from being powered down until all your data has been written. (Works with the USB and FireWire connection only)
Easy to set up, easy to use - Installation is a snap because you don't really install this drive, you just plug it in and it's ready to use.
USB 2.0 interface - A simple connection that offers convenience and compatibility among multiple computers.
Fits right in - Takes no more space than a paperback book. Collect two or more and they nest neatly together like volumes on a shelf.
Smart and energy efficient - Turns itself on and off with your computer.
PC and Mac compatible - Works with both Windows® 2000/XP/Vista and Mac® OS X 10.4.8 or later
Specifications:
Serial Bus Transfer Rate: (eSATA) 3 Gb/s (Max), (USB 2.0) 480 Mb/s (Max), (FireWire 400) 400 Mb/s (Max)
Capacity: 750GB
Interface: eSATA, USB 2.0, FireWire400
Dimensions: Height 166 mm, Length 137 mm, Width 54 mm
Weight: 1.15 kg
Operating Temperature: 5° C to 35° C
Non-operatingTemperature: -20° C to 65° C
AC Input Voltage: 100-240 VAC
AC Input Frequency: 47-63 Hz
System Requirements:
Available USB, FireWire, or eSATA port
Windows® 2000/XP/Vista®
Package Includes:
External hard drive
USB cable
FireWire cable
AC adapter
Quick Install Guide
------- Will this suffice?
