THX1136
Bonehead
This seems obvious, but I'd like some input anyway. Can a passive direct box be used in reverse? i.e. plugging one in "backwards" to convert a low impedance signal to high impedance. The possible use which prompts my question is using a piece of +4 balanced gear between an instrument and it's amplifier - no FX loop available. If not, why not? Would an active DI be different?
I'm looking at it as I would look at a piece of wire. Although there a some who would argue the fact, wire is not directional. Signal can go either way. Since a DI in it's simplest form is nothing more than a transformer with the appropriate balanced and unbalanced ins and outs couldn't a signal go either direction in a useable fashion?
Thanks for any info anyone might provide.
