Delta 66 balanced outputs - or not?
  • Thread starter Thread starter Sangram
Sangram
Hi
My Delta 66 balanced outputs are acting funny. The hot signal is fine with 0 offset and a strong level, but the cold signal has no or very little signal and a very high offset - about 20 mV.
The card was picked up used, and for a long time was run using unbalanced inputs on other equipment, with the cold lead shorted to the shield. I continued till I got an amp with balanced inputs, and now it runs in balanced mode but it's still not fixed.
Would this kind of operation damage the opamps on the cold signal output? Or is this normal with the Deltas? A guy called Rod Elliot has described a 'balanced' scheme on his website which just lifts the cold signal from the signal ground, to create a pseudo balanced operation mode. Maybe this is what it is?
Didn't realise how bad it was till I got my new 1212M, which has a much hotter overall signal (quality aside) and a pure balanced output.
I don't have one to check, but I have heard rumblings that Delta 44 and 66 are not fully balanced but psuedo balanced. This can still be better than simple unbalanced or a badly made fully balanced.
I don't think you have caused this by shorting the cold in an unbalanced Jack. Even proper balanced outs should be designed to tolerate shorts to ground.
Do you have use the Ouptut levels Consumer/Pro -10dBv or +4dBu switch in the delta control panel?
For the record, the more recently designed Audiophile192 which I do have, really does have proper balanced connections.
