delta 44 VS 1212M VS usb interface
  • Thread starter Thread starter bad intentionz
i font have a fire wire port thats the thing and i have no one to install it also hows the emu i hear good things baout it
I have a Delta 44 and it does a great job. In a desktop, if you only recorded on 1 computer, I don't see why anyone would opt for a USB or firewire solution over PCI.
bad intentionz said:
if usb is bad why do people get m boxs?
I would venture to say that it could be a matter of economics or, they're looking for a laptop solution. That's my best guess.
I use the Delta 44 also and think it is a Great Card and very easy to use and it has Twice the Inputs as the FastTrack USB....
If you need the Pre-Amps that the USB one has then get a small Mixer which will also increase your Inputs and Give you the XLR and Pre-Amps but if you are mainly recording Guitar then you can Connect the Send from your Amp into the Delta 44.....
Cheers
im recoridng rap vocals i already have all the pres and such all im getting now is a soundcaed and moniters
