Glen - would you always do this in the mastering phase, or does it make sense to fix DC offset on your raw tracks while mixing?
It's best to nip it in the bud, of course. But to be honest, I usually don't think to check for offset on every single track I make or get. If it's pretty significant offset, it's pretty obvious visually in the waveform and I'll get rid of it right away. But if it's a very low level offset, it's not obvious to see or hear - and frankly most likely isn't going to affect the mixing, so if it slides through the mixing stage, it's probably not a big deal (though it's still best to be rid of it.)
But after summing the tracks to a mixdown, the offset can be additive and get much worse. So between that possibility and the ease of checking it on a single file, there's no excuse not to make that an integral part of (pre)mastering, IMHO.
I haven't seen a DC offset problem in 15 years.** If you have one, the time to take care of it is long before the "RECORD" button is ever pressed.
Well, John, I for one would never send you anything that had offset in it; that would just be rude
. Kind of like sending your kid to the photographer without washing and combing his hair first. I'm not surprised you don't see a lot of it coming your way.
But you are right, it doesn't show up a whole lot these days anyway. Mostly on laptop soundcards for some reason (IME, anyway). But it does occasionally creep in unexpectedly. A lot of times these days when I see it it's not really true offset, but rather a VLF modulation from somewhere. Same solution either way.
And unfortunately getting rid of it before hitting the Big Red Button is not an option for me when I receive tracks for mixing that are from someone else that ain't hip to the DC situation.
G.
