My VE 8 review
I play mostly solo acoustic stuff but I've never really thought about using effects, a harmonizer or a looper, I play straight up. When I saw BOSS put all three in one box however, I changed my mind.
The box is totally solid,well built and has all kinds of connections, including USB, so it can be used as an audio interface. Lots of combinations to fit different situations.You can also use an external foot switch to access different functions.
There are three components, guitar effects, harmonizer and looper.
For guitar you get resonance, reverb, notch filter and a switchable effect of your choosing.Effects like resonance I put under the category of "
sounds different, but not necessarily better". I'll play around with it some more and maybe I'll change my mind.
The effects are by BOSS so they are usable and what you would expect. I kind of wish they would've put an acoustic simulator so you could plug an electric in it. I would gladly give up the ring modulator.
The biggest problem here, all effects parameters other than mix are accessed through sub menus.You really have to make some presets you can live with ahead of time.
The harmonizer is simple, it can be set up to follow guitar chords, to a set scale or a hybrid setting. I used to have a Digitech Vocalist so I have a little experience with this. I think the secret is to take what the harmonizer gives you. I think the biggest failure of these kind of effects are peoples expectations.
I'm a lousy singer but what intrigued me about the harmonizer was playing a harmonica through it. You've got to play single notes for it to work and I need to get the feel of it yet. It's hilarious, it sounds like a horn section. It's definitely ripe for abuse in a good way.
The looper is basic, you can overdub, but there's no undo.That's the biggest flaw. You can port either guitar or vocal to it and this is switchable via an external foot switch.
I never looped before but I got the hang of it pretty quick. For me the secret was not to think of the switch as "on and off" but as a beat. I'll play something three times through,tapping my foot, hitting between one and two and then between two and three so that it's smooth. I've done long chord progressions and percussive beats and it's all been good.
While everything is usable in this box, you could probably go out and buy individual boxes than would out shine the individual components. I think this is a classic case of the sum being greater than the parts. It's a well rounded tool box at what I think is a pretty good price point for what you get and how it's built.
