OK... here's some pics... try not to laugh too hard when you see what I've done
Here's my
existing space with my PC removed and cables all over the place.
I then cut some
vent holes through to the other room. I need these to vent all the hot air produced by the PC and help keep everything nice and cool.
The same
vent holes in the adjacent room, which is our utility room.
I've put some
grilles over the holes to try to make it look nice (I don't think my missus was impressed).
I've filled in all the gaps around my existing space with
synthetic foam (not sure of the spec but it's too late now cos it's in). You can see the 12cm case fans that I've stuffed in the vent holes. One blows and the other sucks (rude comments expected at this point).
Here's my
PC in position. I've taken the front facia off the PC because I found that I got another couple of deg c cooling by doing so.
I then cover the front of all this with
large foam panel cut to fit snuggly around my PC.
And finally a nice big piece of
3/4" MDF to finish it all off.
Looks gruesome I know but it appears to work quite well. What I had already done was purchased and fitted a new quieter PSU plus a new CPU heat sink and fan with variable speed (work OK on slowest and therefore quietest speed) and a new quiet 12cm case fan and that did help.
It's great to sit in my room now without all that noise (which I had gotten used to over the years) in the background.
Having said all that... I've always wondered whether I did the right thing opting for an AMD PC rather than a Pentium. Seems to me that AMD's have always made a racket.
What I'm going to do next, cos I can tell that you are all riveted with excitement and interest, is produce a couple of sound files so you can hear the difference between before and after my project.
cheers
andy
