G
Goldenvoice388
Well, I took the 388 in to a reputable repair outfit in Portland this fall for a tune-up, to the tune of $450. First was hopefully an alignment would fix a #1 fading away. Then a call for a head-re-lap. (ouch) - but, OK, if it'll fix the problem. Then a week later, a call that it needed a bias amplifier... OK, fine, get-er-done.
So on pick-up, a comment about #1 still being a bit "odd".
Well, tonight I ran a 180Hz test tone to check levels.
I charted it out, but, for example, recorded at -10 on the meters, the tracks look like this:
1 - 2 - 3 - 4 - 5 - 6 - 7 - 8
+5 +5 0 -7 -4 -10 -8 -11
Does this tell us anything? I did listen quickly through the channels, and 1 & 2 are indeed louder through the monitor/headphones upon playback. #2 wobbles around by 3 db.
So I aimed for "0" on playback. These are the levels I must record at to get "O" on the meters on playback.
-20 -20 -10 -3 -6 -1 -2 0
Any analogdogs have any ideas? I guess I pretty much feel like not dumping any more $$$ into this thing. In fact, makes me leery of old analog recorders in general.
Is there anything that can be done about $$$'s spent, or is this just the nature of the beast?
How would you handle this?
Help. Goldenvoice
Help. Goldenvoice
