cusebassman
Freakin' sweet
Farview was kind enough to pass along a Sek'd Prodif T 2496 PCI card which has two TDIF inputs and DTRS sync connections. I've got a Tascam DA-38 connected to the TDIF-1 connection and the sync cable hooked up.
Everything is going good - Cubase sees the individual TDIF inputs, I've got the clock set correctly, and audio is coming in correctly when I play a tape and record to 8 tracks in Cubase.
My question is, since the DA-38 tapes contain 16-bit 44kHz audio, should I set the Cubase project to record at 16-bit, or will recording to 24-bit suffice / for some reason be better?
