A friend has an essentially new (2.41 hrs) DA-38. He was able to record with it using a Universal Audio 610 solo pre-amp connected via a cannon connector to multi-pin snake. It was working fine, but after unplugging Channel 4 from the back of the 610 and replacing it with Channel 5 of the snake, the machine shows very distorted, very low level. This is consistent with all the channels he has tried (4 of them). He also tried using a Yamaha board (1/4 " to RCA connector) and gets the same results.
Any thoughts on what's going on? Any chance he burned out something in the process?
Thanks!
Thanks!
