Bart HRK
CS566 | Processing Channel Strip with VCA Compressor, Console Emulator, 4 Band EQ and the Active Transformer
The CS566 is an Ultimate Analog Studio Processor dedicated to Professional Music Producers and Audio Engineers.
The CS566 is a result of the Extensive Development Process. The circuitry of each stage was carefully tweaked to produce bespoke performance.
The CS566 has independent +/-12dB input-output level controls to match a source signal level and the sensitivity of the following processing studio hardware in the signal chain.
The Custom Discrete Opamp VCA Compressor relates to the classic discrete VCA modules used in the '70s and '80s.
The CS566 compressor provides extensive control over the signal dynamics envelope while enabling straightforward operation.
The HRK Solid State Drive Console Emulator is a result of a completely new design approach to Analog Saturation and Harmonics Generation.
The CS566 features Four Band Equaliser. Each Band has two frequency settings.
The Augmented HRK Active Transformer adds the final touch to the processed signal by injecting additional harmonics and forming the frequency response of the classic transformer output stage.
The CS566 is a compact and easy to use line level Channel Strip featuring all essential tools for Tracking and Mastering.
More Info:
https://hrkshop.eu/product/cs566-processing-channel-strip/
Great review of the CS566 on the FB HRK User Group.
- Ultimate Proffesional Analog Studio Proccessing Tool
- Enhance Your Tracks and Mix with Analog Harmonics
- Upscale Your Mixing and Mastering Ability
- Create Top Rate Results Effortlessly
- Features HRK Solid Stated Drive Console Emulator
- Flexible Input and Output Level Controls
- Discrete Opamp Custom HRK VCA Compressor
- NOS Military Grade Transistors from the '80s
- Easy to Apply Soft-Knee Compression Curve
- Post Compressor HF Auto-Enhance Feature
- Stereo Coupling Feature for Stereo Operation
- Four Band Ultrasmooth Equaliser
- Two Frequency Settings for Each EQ Band
- Musical and Intuitive EQ Filters Curves
- Augmented HRK Active Transformer Output
- Line Level Signal Processing
- High Headroom up to +25dBu
- Multiple Sources of Subtle Analog Harmonics
- Ear Picked Studio-Grade Low Noise Opamps
- High-Gloss Black Gold Pearl Finish Front Panel
- Balanced Input and Output
- High-Quality Audio Potentiometers
- Compatible with API 500 Format
- Direct Sale - Save on Distributors Fee!
More Info:
CS566-SATURATION-CHANNEL-STRIP-4-BAND-EQUALISER-HRK.jpg152.2 KB · Views: 2
CS566-SATURATION-CHANNEL-STRIP-4-BAND-EQUALISER-HRK-1.jpg191 KB · Views: 2
CS566-SATURATION-CHANNEL-STRIP-4-BAND-EQUALISER-HRK-fab.jpg275.7 KB · Views: 1
CS566-SATURATION-CHANNEL-STRIP-4-BAND-EQUALISER-HRK-STEREO-BUS-PROCESSING.jpg236.9 KB · Views: 2
Screenshot 2022-03-28 at 13-49-08 CS566 PROCESSING CHANNEL STRIP WITH CONSOLE EMULATOR.png128.1 KB · Views: 2
Screenshot 2022-03-28 at 13-49-34 CS566 PROCESSING CHANNEL STRIP WITH CONSOLE EMULATOR.png133.3 KB · Views: 2
Screenshot 2022-03-28 at 13-49-43 CS566 PROCESSING CHANNEL STRIP WITH CONSOLE EMULATOR.png93.1 KB · Views: 1
CS566-SATURATION-CHANNEL-STRIP-4-BAND-EQUALISER-HRK-FP1.jpg124 KB · Views: 2
