timboZ said:
I'm pretty sure both articles are slightly inaccurate, but they're on the right track.
The first one implies that subcode data exists on a blank disc. It does not. Subcode data is data hidden in the underlying encoding generated by the drive when burning a disc. It includes, among other things, CD-TEXT data, ISRC codes, and various other bits of information, all of which describe the content of the disc, which obviously means that it can't be on the disc prior to burning it.
For more information about subcode:
http://www.ee.washington.edu/conselec/CE/reports/Group.1/matt_page_individual/subcode.html
The second one implies that a portion of a CD-R Audio disc is pre-burned. This isn't quite right, AFAIK. The difference between an audio CD-R and a data CD is a special area of the disc which is... I believe... between the main recording area and the center hub, but I may be wrong. In any case, I don't think the information contained there is burned. I think it is pre-stamped on the silver backing.
Anyway, this area contains information that indicates that the disc is a burnable disc, tells the manufacturer, batch information (I think), and the type of media. If memory serves, the optical drive actually burns over part of this region when it finalizes the disc, thus effectively converting it from a CD-R into a CD... but I could be remembering wrong, or I may be thinking of DVDs.
