How do you get that big crashing snare sound (think Def Leppard or the Cure)? I've played with EQ, compression and reverb (in that order) and while I'm able to bring it up with compression the reverb just seems to move it back in space and thin it out. My problem has always been a snare that sounds to weak in the mix. If someone can maybe describe a technique and the signal chain they use in the mix that would be helpful. Thanks.
