B
bbundy96
Does anyone know the normal ranges for CPU and motherboard temperatures? My CPU was at about 130 degrees F and the mobo at a little above 105 degrees F. They reached those temps after recording for about 2 hours. I have the standard CPU fan and 2nd front case mounted fan.
My workstation desk has a compartment for my tower and is maybe only 2" wider than my case, 4" taller and maybe 3" longer. I have two port holes in the back of the compartment (3" dia.) for cables to pass thru and was hoping that the heat inside would be able to leave the compartment thru that. Any ideas on better cooling?
thanx.
jim
thanx.
jim
