Could it work???
  • Thread starter Thread starter Jagg76
J
Jagg76
I have attached a drawing of my basement.
I want to create a studio in my parents' basement (I myself currently live in an apartment). There is only one place where there's room to do this (which is marked in the drawing). In that empty area, the walls and floor are cement and the ceiling is unfinished (wooden beams) and there is a busy street on the wall side. Does anyone think this could work? And if so, where would I go from here as far as building, soundproofing, etc...? I don't want to invest a great deal at the moment seeing as this would be mainly for recording demos for my own work. As long as I get something half-decent for local radio play. :cool: (Maybe a $1000 budget for now). Any constructive ideas would definately be welcome!
9 X 7 is pretty small actually. What exactly are you looking to record, instrument wise? You'll need a great deal of bass trapping so the room doesn't turn out so boomy. But if it's the only space you've got and it has to work, then yeah, you can make it work.
Update your profile so we know where you live so we know what materials to recommend. Then look through a bunch of posts and read up. Read all the stickies. Get to know the theories and facts behind sound proofing a room.
Oh yeah... no stickys here... shit...
Umm... just read through a bunch of posts.
Here ya go, read through the stickys at John Sayers' site. :) www.johnlsayers.com they're very useful.
Actually, this is a tough one. I can only think of one word. COMPROMISE.
Soundproofing is a misnomer. There is no such thing. The proper word is TRANSMISSION LOSS, which is how much sound makes it through the envelope assemblies vs how loud it is outside of it. Transmission Loss is rated in DB. Assemblys such as a studwall are tested in labratorys and are RATED according to how much sound is TRANSMITTED. Like this:
The question is defining how much do you need . If you can't define your compromise point, then you can't define what you need. Heres a few considrations as well.
Loss of space is proportional to Low frequency Transmission Loss goal
Trapped Low frequency within requires low frequency absorption which also causes loss of space.
Low frequency rumble(structural transmission) from the street may be difficult if not impossible to prevent on this budget. Even with a large budget, and a larger room. Short of floating a room within a room, or other decoupling methodologys such as resiliant channel or Risc isolators, mass is your only option. Add layers of drywall untill structural failure or your isolation goals are met :D Ha! Just kidding However, there is a limit of diminishing returns using mass alone. The limit in this case is space. Possably the floor structure above
as well. I know of builders who utilize 5 or more layers of drywall in a small room to prevent 110 db transmission:eek: This is the reality.
Use of Resiliant Channel requires venting or removal of drywall leaf in proposed room prior to installing the RC. Up to two layers of 5/8"drywall can be fastened to RC. Many decoupling and fabrication details to address.
If you have a hollow core door, change it to a solid core. Install door seals, thresholds, , insulation in all walls, caulking or gasketing electrical outlets and lighting fixtures, pipes and all other flanking pathways.
HVAC or ventilation is required in a sealed envelope. However, ducting connected to other rooms can be a flanking path for airborn noise transmission to and from the studio.
For the open cieling, assuming the floor sturctural framing is up to code, adding 2 layers of drywall(5/8")directly to the underside of the subfloor, between the floor joists will help. Usually by adhesive/screws and or cleats/screws. Then caulk ALL joints, pipes, ducts, etc. Remember, this becomes added mass to the floor LEAF. That makes it important to NOT trap air or create an airgap between this mass and the subfloor. Once insulation is installed between the floor joists, use 2 layers of drywall with staggered and caulked joints. This becomes the SECOND leaf. This leaf may be fastened directly to the joists, or Resiliant channel may be used, but that is determined by your goal. If structure born noise such as foot patter is a problem, or you want to play loud at two in the morning, RC is definetly in the picture :p
Well, I'm out of time. Hope this helps some.
Here is a cieling detail with a double wall.
