G
Goreliscious
Is the theory behind drum recording the same for guitar amp recording? - You can take something out but you can't add it in. E.g you could probably make a close mic'd snare sound distant with some effects, but you'd struggle to make a far mic'd snare sound close.
I know that regardless of the instrument you should try to capture the sound as close to what you want the finished product to sound like, so if you definitely want a distant sounding snare drum, stick the mic far away to start with rather than rely on effects to create the illusion...but coming back to guitar amps...if you get different sounds out of the cone at different points, is it safest to aim the mic at the middle because you'll get the most to play with in the mix?
Last time my band recorded we played around with guitar amp mic position but eventually settled for bang in the middle because the consensus was that if it was too harsh in the mix, we could dull it down, but if we had recorded with the mic at the edge of the cone and it came out dull in the mix, we'd struggle to give it some crunch.
Any words of wisdom on theory would be much appreciated!
