James HE said:
Your tracks aren't going to sound any better converted to 24 bit, they might even sound worse actually.
-jhe
Not true James, at least the part of them sounding "worse". I agree though that they won't sound any better per se.
What WILL sound better is your plug-in's working with 24 bit files. Basically, a plug-in applies a algorythm to the original sound. The original sound has to be re-created because of the calculations the plug-in does. Your bit depth will increase. But, if you only have 16 bit files to work with, and play back at 16 bits, the extra bit depth is either "truncated", meaning the extra bits the file now has must be eliminated, with no interest if that may SOUND good or not, or they can be "re-dithered" back to the original bit length. Dithering simply add's a noise at the threshold of the sound to noise ratio spec of the bit depth you are working with, but you also lose a couple or few dB of sound to noise ratio BECAUSE of the dither, but this is considered a good trade off over truncating the word because the noise will hide the sudden elimination of sound.
Anyway, that is all technical talk about dithering and what not and not the subject at hand here DIRECTLY. But you need the background to understand what is going on when you apply DSP (which could be something as simple as changing the volume of a track in a software mixer. The .wav file must be re-calculated to create the new sound that is lower in volume....you get the idea here....then the bit depth is longer, thus you need to truncate, or re-dither is to the original bit depth it started out at). Blah blah blah.....
Now, the nice thing about 24 bit word length's is that you have the potential for much more signal to noise ratio, thus, when you apply DSP to a .wav file and the bit depth increase and get addressed by truncating or re-dithering, the truncate or re-dither happens AT A VOLUME THAT YOUR EAR CANNOT DETECT! Thus, you hear a far more natural sound and the result of the DSP is much smoother. Do this make sense? It is sort of complicated, but I have done my best to simplify the advantage (and those that may have a little more insight to the actual workings of all this, please cut me some slack for oversimplifying some of this.....thanks....
So, yes, you SHOULD work with higher bit depths IF you plan to do ANY DSP to the original file. Even though the resolution of the file will not change just because it is now a higher word length, your file will sound much better after DSP is applied to it.
If you only have a couple tracks though in the project, and you don't anticipate having to do much DSP on them, if any, then the 24 bit increase will not mean as much, and as pglewis stated earlier, the more tracks you add, the more advantage you get with working in the 24 bit realm.
Be aware too that longer bit depths mean a bigger load on your processor too. You may not be able to play back as many tracks, and you will certainly not be able to apply as many real time plug-in's to the tracks before your processor is overloaded.
But if the original tracks sound very good, and you don't need a gazillion tracks, you should be okay.
Hope this helped clear the air a bit for you. Good luck!
Ed
